Q45a: Active Suspension uncontrolled rocking, left to right
Ccdiesel
Car: 1994 q45
Anyone every experienced this?
q45a with 93k miles, fresh Texasoil accumalors on each actuator. Fluid levels are good. No leaks. SWAY bar is intact. Car will randomly lose its ability to maintain balance and it will start rocking, left to right only, when thrown off balance. Eventually it stops and goes away. Not sure where to start with no codes, and most of the time it is working correctly. Seemed to start as the temperature dropped.
Status of the last time the fluid was changed I do not know, and I am not sure changing the fluid would cause what is happening. Any help is appreciated. Thanks!
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Did you see Diagnostic procedure 11 in the 1994 Q45 service manual?
http://www.nicoclub.com/FSM/Q45/1994_Q45/fa.pdf
Also see page FA-84
Ccdiesel
Car: 1994 q45
Thanks, I found that. Not sure how to get to those sensors but I'll try. But it is doing the tilt at start up. And raises and lowers. Maybe the vertical sensors are bad as well?
Infinitiguy19
Do you have a Nissan Consult cable? If so use ECU Talk to check the sensor values.
Ccdiesel
Car: 1994 q45
No I don't, probably need to invest in that.
Where can I get that? Then just download ECM talk?
Infinitiguy19
ECUtalk.com
Ccdiesel
Car: 1994 q45
Is that better than the consult?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
A Consult can do everything, so no.
First thing any active owner must do is search for all posts by texasoil, including including General Chat.
S_PerezQ45
Car: 2002 Infniti Q45
Kind of sounds like Lower Control Arms your bushings might be worn out. I have the same problem i think whenever im driving and my front tires hit lets say a crack in the road or a little dip in the road the car will move quickly left and right seems like the tire is getting pushed out of place. I had my mechanic check my suspension when i changed my starter and he said my lower arm controls are old and need to be replaced and i also needed new Struts but struts just keep your car from bouncing so much. So maybe check your Lower Control Arms
Ccdiesel
Car: 1994 q45
This was not a control arm issue, active intermittently adjusts sway through the g sensors incorrectly. Texasoil, given that this is intermittent does not think it's the sensors. But the code I get is 14 for the g sensors. I need a 98805-64U00 sensor to try but they are no longer made
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
You still need to read all of texasoil's posts.
Contact Keith Bowers at his website. http://www.activesuspensionsystems.com/whyforq45.html
Infinitiguy19
I have read what I believe is all posts related to active suspension. Knowing is one thing but doing something with the knowledge is another. Just because you know how the system works doesn't mean the person performing the work to the car does.
Do you have any other codes besides code 14? Follow the instructions in the service manual for the Lateral G sensors. Who told you the sensors are no longer available?
