If you havent been properly welcomed to NICO, here it is! WElcome to NICO
Mint Q45A wrote:Hello,I need to replace the water pump - it has been leaking a little bit for awhile, but in the last couple of weeks it has gotten worse.Questions:1. I assume I will not require any special tools. Correct?2. Where could I find some general instructions on the steps to follow?3. My main concern is how to purge the system (to eliminate all air trapped inside while doing the exchange). Any advise?4. Am I supposed to use a gasket or a gasket maker (silicone type)?
Any advise is greatly appreciated.
1. You're correct... Just basic tools2. Right here:- Remove cooling fan- loosen fan belt via the tensioner on the drivers side. sometimes people just take the idler off... - Remove water pump, DRAIN COOLANT BEFORE DOING THIS, unless you dont mind the floodgates opening.. I generally just let the coolant spew out and then hose down the driveway.... Im convinced its fairly impossible to drain Q45 coolant without a mess ensuing.- Remove all traces of liquid gasket- Put new liquid gasket on- Install water pump- Fill coolant
3. Generally what I do is fill it up and try and burp the hoses (squeeze them a few times)... then jusdt carry coolant with me and fill the overfill tank for the next couple days and top off as necessary.
4. See above.
