so what you mean?i wanted to just add pipes after removing the suit case.......straight pipes you think i'll still pass like that?i just need my new tags you know?qsiguy wrote:I've never heard of anyone failing emission/inspection for removing the suitcase muffler. Maybe if you didn't install new tail pipes with tips. I've failed before because the exhaust terminated under the vehicle.
why would i do that?i just want an extension bar and then the tips to where the oem tips were.MinisterofDOOM wrote:Haha, sorry, I just meant make sure the tips are not underneath the car.
that'll be when i get another Q45.im hoping my Q turns out the way i want it.like i said results i'll post once done thanks for your help.qsiguy wrote:What you are planning is exactly what you should do, just go for it. Get some nice tips and forget about the exhaust. Never any reason to do anything more unless something rusts out or breaks. Don't waste money on fancy mufflers and such. Next time you touch the exhaust will be when you install your turbo
