sancem wrote:The rims and tires are slightly different sizes. 17X 7.5 with Bridgestone Potenza 225.50.17 Front17 X 8 with Bridgestone Potenza 235.50.17 Rear
With those wheel sizes, you can use 245/45-17 tires - many of which will be the correct load index. Do a search for an old post of mine that has a list of possible tires that would work out well in that size.
Also, I hope that the wheel offset is 33mm minimum to 38mm maximum (certainly not more than 40mm), else the fitment to a Q45 might be problematic.Quote » Does that mean I can't rotate them? [/quote] If you use different size tires (as you mention above), then you should not rotate. If you put 245/45-17's on all four wheels, it may not be a problem per se, but might be better not to rotate them.
Z
