Q45 Wheel Question.
Apex45
Has anyone tried to install 2003 Q45 wheels (18x7.5) on a 1993 Q45?
I'm trying to see if they fit. are there any rubbing?i think the stock 1993 Q45 wheels are (15x6)
if anyone has experience in this i would appreciate the input.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
There is someone here that has the 18s on a Q. I dont know who, but someone will chime in. It does work, and fits fine...
They will fit and are very near the stock diameter (if you keep the factory '03 tires).
jtesensky
Vendor
Car: 2005 Infiniti QX56
2002 Infiniti QX4
AZ is right, the overall diameter of the 2003 18" is the same as the 1st gen 15" (with tires). P.S. Greg, say hi to Quella for me-Joe
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Apex45 wrote:I think the stock 1993 Q45 wheels are (15x6)
Stock is 15" x6.5".
So you are gaining mostly metal weight and less load carrying capacity than a comparable wheel in 15", 16" or 17" diameter, especially if said wheel has an 8" or 8.5" rim (allowing for larger tires).
eQlipse
Car: 2006 Infiniti M35X
jtesensky wrote:AZ is right, the overall diameter of the 2003 18" is the same as the 1st gen 15" (with tires). P.S. Greg, say hi to Quella for me-Joe
Does anyone know if they'll also work on a '97 touring? I've been contemplating acquiring a set & also using the same tire size as the '03 Q. I believe they're 245/45/18's.
GEOFF
Car: CARS/BIKING
I just bought those rims from Apex45 for my 95 Q45t. So I use 245/45/18 or 245/40/18. Tirerack suggest 40's, but I think it should by 45's. Can someone verify this for me?....Thanks
No need - Just go with the tire that has the higher load rating. Should be 96 or above for the Q.
eQlipse, they'll fit fine.
Apex45
Should stay with the 40series tire, they closer match the stock tire diameter when you go plus 1, 2 or 3 sizes.
GEOFF
Car: CARS/BIKING
I have discovered the 40 series would result in a 25. 71 overall diameter, or about .28 inches less than stock. This would be good, except the load rating of that size tire is not very high. 45 series tire overall diameter is 26.68, or .68 more than stock. This size tire provides sufficient amount of load rating. It sounds like I may have higher risk of tire failure and rim damage with the 40 series, but just not completely sure.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
245/40-18 will not give you enough load capacity. 245/45-18 will, although at a larger rolling diameter.
Perfect is a 255/40-18, but 8" is the minimum rim width, with 9" being preferred.
http://www.nissaninfiniticlub....44586
Moral of the story: The third generation Q45 is a lighter car than a first generation Q45, and it is still minimally tired.__________________Brian1995 Q45 & Q45t
Q45tech
A good accident investigator [witness] can always prove it was your fault when you run tires that don't meet oem specs. You maintained your car in a negligent and unsafe manner! They will check your brake pads also and read your ABS computer for your speed prior to deloyment.
Why you should always at least match the load limit and speed rating if possible. One less thing in life to worry about.
People assume that because they don't speed they don't need V,Z rated tires what they don't understand is that the speed rating is a durability rating also.
V,Z tires out stop S, T tires by a wide margin in dry and wet due to internal rigidity and tread design.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
maxnix wrote:http://www.nissaninfiniticlub....44586
The link should be to Michelin Pilot Sport specifications.
Damn, Nancy, us late night posters need more than a 30 minute window to edit our mistakes! __________________Brian1995 Q45 & Q45t
Q45tech wrote:A good accident investigator [witness] can always prove it was your fault when you run tires that don't meet oem specs. You maintained your car in a negligent and unsafe manner! They will check your brake pads also and read your ABS computer for your speed prior to deloyment.
People assume that because they don't speed they don't need V,Z rated tires what they don't understand is that the speed rating is a durability rating also. V,Z tires out stop S, T tires by a wide margin in dry and wet due to internal rigidity and tread design.
So true - This should be required reading for anyone prior to walking into a tire store.
Tire sellers should be held equally liable - They'll sell anything to anyone.
Why a dumba$$ kid can walk into a store and buy cheap 185/70/13's with whitewalls for his '84 Caprice BUT he can't buy a Glock without a waiting period is beyond me.
Which is more lethal?
Hmmmmm.....
GEOFF
Car: CARS/BIKING
:ylsuper I just bought dunlop sport 9000 245/45/18 for the 03 Q rims. I think they should do the job.
