pasadenaQ »
https://forums.nicoclub.com/pasadenaq-u4461.html
Mon Feb 03, 2003 7:21 pm
Hmmm. I appreciate your position AZ. I am simply going by my own personal experience that was initially based upon 3 different articles (with particular reference to a Road&Track "Tech Tid-Bit " article that was full of thought-provoking data). The bottom-line is that the car came stock with 16's and I tested 3 different profile treads that sucked (for me). I had to slam my car to the ground like pimp-mobile and I had too many problems with minor clearances as I drove over the slightest bumps. On the other hand, anything with higher profiles didn't seem to perform as well as the same O.D. 17's. So, I then tried 17's and 18's and the 18's (with similar tire brands, wheel weights, and tire weights) gave significantly better results. Keep in mind that although I researched masses of data, the bottom-line is that I needed to test to see what worked best for my driving style, conditions, and car setup. That being said, more power to the people running 16's out there if it is the "ideal" setup for them. For me, 18's seem to have the best all-around compromise with a weight towards performance (Keeping in mind that the car is 4300 pork-ridden pounds of a luxury vehicle). By the way, my rims are extremely light, but they cost $800 each (big downside).
So, my question should have maybe more clearly and unprovokingly stated :"18's are the ideal for 'my' situation, and does anyone have any wheel/tire experience to suggest a good combo?"
