elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Fri Oct 31, 2003 12:03 pm
The Q is NOT, repeat NOT a good snow car..... TCS does essentially nothing in the winter..... TRUST ME!!!!!
If you wanna make it a winter car (and you are already an experienced winter driver.....), you need 4 things.....
1. Studded snow tires for the rear, and preferably non studded for the front2. 100lbs of weight in the trunk (sand or salt, so you can use it to get unstuck)3. A small plastic shovel.....4. A chain (so someone can pull you out.... Thanks infiniti for the tow rings in the front)
I would also recommend having a blanket and some other essentials........
As far as LS vs Q....... I would say the Q, but it depends on what you want..... The LS is a bit more smooth and quiet, but doesnt have near the power or the handling.... Both are pretty equal when it comes to maintenance and reliability.... I dont know how Lexus parts compare to infiniti parts....... The lexus also does have a bit more rear seat room.......
I dont think you can get a moonroof for the Q, but a sunroof is standard (almost sure)..... I would assume the same about for the LS.....
But, you should be able to get a 94 or 95, in GREAT condition with GREAT maintenance, and under 100k for 6-10k easy..... I think you'd be much harder pressed to find a LS that meets that criteria...... Unless you wanna go down to about a 90-93 in the lexus.......
The Q45t doesnt really have options that the std Q doesnt have, except for the touring package...... in 90-94 it had HICAS 4 wheel steering..... 95+ dropped this...... All Q45t's had a rear sway bar, which the STD lacks.... Heated seats and TCS are fairly common options.....
Chain guides only apply to 90-93...... 94+ is safe..... transmission problems can usually be detected by driving...... If it shifts pretty strong and the fluid is good, its probably OK......
