yeah thats what i was thinking.... Its because the Q starts in 2nd.... Shift it into 1st and see what happens....... That is, if you have any tread left on your snow tires!!DrewQ45 wrote:Get a 1993 TCU (search for part number) so your car takes off in 1st versus 2nd gear.
...Drew...
Lots of interesting and informative reading Q45tech...thank you.Q45tech The Furd accels 50>80 in 7.8 seconds vs Q ~~6.5..............1990[ecu wrote: 5.8HOWEVER both take 3.2 to get zero>30mph
0>80 = 14.43 for Furd [2006] and 12>10.8 for Q45 [95> 90ecu]
2.43 secs is pretty significant to 80 mph
They forgot to mention the styrofoam rear axle bolt covers that are supposed to keep the car from exploding in a rear end collision... apparently only cops get rear-ended at high speeds.Q45tech wrote: "Contrary to public perception, there are few outstanding differences between the police interceptor and standard civilian Crown Victorias.
That's interesting because if I recall (and I may not be correct) it was the aluminum driveshaft in the non-LSC MKVIII that limited it's top speed to 130 mph.Q45tech wrote:.. an aluminum drive shaft
My understanding is that the 90-93 Standard and Active ECUs are physically the same with some hardware differences with the ECUs for the TCS. The programming is the only difference...lino wrote:Question #2: Is there a performance difference if a NICO ECU is programmed on a 1990 ECU or 1991 ECU? Are any of the 1990-1995 interchangeable?
As the driver or the back seat driver ?AZhitman wrote:
The Interceptor was my state-issued ride for a little over a year.
I assure you 95% of the time, Greg is the driver.lino wrote:As the driver or the back seat driver ?
well, there was this one time, back at band camp.....lino wrote:As the driver or the back seat driver ?
I remember there was a post of a guy who twin-turbocharged 4.1 or 4.5 engine for a river speed boat. Imagine if that could be done within a Q45 engine bay - monster powerplant. Definately beefing up drivetrain would be mendatory procedure!Cheers!Q45tech wrote:Obviously a 32V8 Cobra engine with nitrous and supercharging can improve things over stock. 11.98 @ 115 mphhttp://www.mercurymarauder.net/forums/
