Q45 vlsd J30 vlsd
FaRmBoiJiM S13
Car: Cars, workingout, girls
Does anyone know what is needed to put a Q45 vlsd into a 92" 240sx. because i had went to the install link on the begening of 240sx.org and they say no mods is needed but when i went to get one at the junk yard its 5 star bolt pattern and that wont work. do you know if i can just use the whole axle and diff of the Q45 will that work or what, because im confused and does any if the J30 have a 3 set of 2 bolt pattern on the output shafts because also on the install site it says pre 95 J30 needs new output shafts but i havent got to see the any after the 95 model do those have the 3 set of 2 bolt pattern
Please help.... THanks...:D:help :help :help
RatedR
Car: my beautiful young asian schoolgirl wife! Hehehheheeh, yes, its a "field trip". Yeah, a &q
Later j30 made from 95 and up should just bolt right up. If you have a 94 and below, you'll need the axles as well. I'm not sure, but i heard that the middle of 94 the j30 had the 2 by 3 flanges. Does anyone know what size nut the axles have for a j30?
