I normally use my 30mm Axle Socket but it maybe 28mm. I know I use the 30mm on it to remove Harmonic Balancer bolt and to hold it still while removing Torque Converter Bolts. I say it maybe 28mm because there's a little play but no slippage.David Steele wrote:What size is it? Its very large...
If I understand your question conrrectly ...David Steele wrote:What size is it? Its very large...
The crankshaft pulley bolt is 30mm.David Steele wrote:I tried that I need an exact size I have really strong impact/air compressor and slipped off of it nasty. ( I've done it before).
It's not in EM-17, they dont really give the sizes to anything. ( I have the book)
Try to get a 6 point socket as the 12 point can sometimes strip out if used with an impact wrench. Its rare, but its never happened on any of my 6 points sockets, only the 12's.David Steele wrote:Thanks I managed to get it off with the 32mm with a 2nd try by pressing very hard against it the bolt faired well, off I go to get a 30mm impact.
Thanks people.
I'll take it with me to sears and try a couple of sockets to really make sure.
Modified by David Steele at 9:05 PM 10/7/2006
In automotive classes I took, I was taught not to use 12 point for high torque its just only for limited movent.anlasak wrote:Try to get a 6 point socket as the 12 point can sometimes strip out if used with an impact wrench. Its rare, but its never happened on any of my 6 points sockets, only the 12's.
