maxnix wrote:1.) Only if you have a bad cooling system! Extended idling with all accessories on a very hot day may get you close to that.
2.) Wow! News Flash! I am sure the NIssan are turning in their engineering degrees as we speak!
1.) We have really hot summers here in the Sacramento valley even with a good cooling system temperatures do climb to the 200F degree coolant temperature with A/C on and idling in traffic.
2.) The main reason they didnt use 1/0 gauge battery ground and alternator power wire was cost. 1/0 gauge copper wire gets expensive so to cut costs manufacturers only produce what they can get away with.
