Q45 Vacuum Hose Sizes
mxr662
Car: 1990 Q45 Desert Sand 81k Sold
My under plenum hose replacement is coming along fine. Coolant Y-pipe, knock sensors, and fuel rails have been installed. All hoses in the kit from Joe have been replaced.
The vacuum hoses are soft, but upon closer inspection splits were found.
A previous post stated that the hose sizes were metric.
Does anyone know:
1. How to tell what size hoses are from the part numbers.
OR 2. How much of each size hose to buy to replace at least the hoses that will not be accessible when the plenum is replaced.
Some of the part numbers are: (with a * substituted from the odd symbol on the hose)
3*0221 4 inch long hose to left side fuel pressure regulator3*0119 5 inch long hose to right side fuel pressure regulator
These two hoses have small splits. Appear same size but much different number.
Thanks
Andy
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
There is a part number from Nissan that includes more than you will need of the correctly sized hose. CAll Joe and he can look it up on my recent order.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Im pretty sure your talking those tiny vacuum hoses without clamps, you can just get generic stuff from autozone.
ponzy
Car: infiniti q45
Andy, its better to use a metric sized hoses.., but the standard ones that are available in local shops and stores is ok. Just make sure its tight enough and not kinked. i brought pieces of mine to a local store, have them compare to the ones available.
i think those are the ones underneath the TB. i cant picture out the vac hoses on the fuel pressure regulator and damper (l-r ?) the ones near them i think are the heater hoses besides the fuel injected hose?
qsiguy
Car: 1994 Infiniti Q45 Turbo
When I bought my plenum kit Joe told me to just get the small vacuum lines at the auto store. He said it wasn't worth it to get the stuff he has.
elwesso
2007 BMW M Coupe
qsiguy wrote:When I bought my plenum kit Joe told me to just get the small vacuum lines at the auto store. He said it wasn't worth it to get the stuff he has.
For sure, because Joe USED to sell the stuff by the foot but now you can only get it by the reel, which is realyl expensive...
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
elwesso wrote:For sure, because Joe USED to sell the stuff by the foot but now you can only get it by the reel, which is realyl expensive...
Actually it is very cheap at about $6.50/ft as opposed to $13/foot.
$37.76 for 2.5 meters.
