Eswift »
https://forums.nicoclub.com/eswift-u367.html
Wed Oct 23, 2002 3:24 pm
an earlier q engine would probably fit in the 300zx NA because the J30 has less lateral clearance for the VG30DE than the 300zx, yet it could fit the VH4(whatever). thus, the engine should definitely fit into the 300zx. the only question is that since the engine only was in the JSPEC j30, there might be clearance problems with the left hand drive j30 or 300zx that prevent correct fitment. (for the same reason a VG30DETT will not fit into the j30 without major modification due to the location of the power steering. SO, if your serious abou this, check out the clearances youve got between US and JSPEC on these cars.
