Q45 Upper Stop Light
kkipping
Car: 1999 Infiniti Q45
Sounds simple, but I can't figure out how to remove the upper rear stoplight on the rear deck. Manual isn't much help. I need to change one of the bulbs and remove a couple of dead bugs. 1999 Q45. :confused:
qship96
Car: 1996 Infiniti Q45
Should be in the owners manual, but try pushing the assembly to either the left or right to dislodge it- be sure to replace BOTH bulbs,so you do not have to repeat the procedure anytime soon.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
It should bayonet counter clockwise 90°.
kkipping
Thanks guys! Actually, the Owner's Manual does give more info than the shop manual. It tells you to push to the left while pulling out at the same time. Works great.
