Q45 transmission reliability:
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
I baby Layla mostly. Just when an M3 is riding my but, I had to give him a run.
My goal, is to get another 50K out of the transmission, and another 200k out of the enigne. We will see.
pretzelboy
417,000 is a good goal.....I know lots of people that have got high 300's out of Jap cars.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Jeff are you still driving the silver Q primarily??
Jeff Williams
2000 Infiniti I30t
2004 Infiniti M45
Yes, I just put new tires on her, and had the transmission flushed and the filter changed. The black one is in waiting. I just bougth a car cover for her.
tyndago
rsiwicki wrote:95 Q45 now at 148K120,000 miles (lost reverse function - never had a problem or a hint of a problem until one day the car would not go backwards - rpms just rev'd)
Do you know why you lost reverse ? I have a 95 with 185k that just lost reverse...
rsiwicki
Car: 95 Q45T
Wow!!! 3 transmission's with the exact same problem. All I remember is something about the valve body failing or not lubricating. Sorry I can't help you out more. ya might want to explore putting in a 90-93 transmission for the better first gear acceleration if you have to do a transmission swap.
5seryan
Car: 1995 Q45t R.I.P.
I lost reverse as well at 112k. Got the trans rebuilt and it hasnt felt the same since. I miss my old car.
texasoil
Car: '92 Infiniti Q45A
'94 Infiniti Q45A
'94 Mercedes-Benz SL600
you should add a pint bottle of LUBE GUARD (the RED bottle) to your transmission fluid. It will eleminate the chatter/shudder. Lube Guard is absolutely the BEST lubricant for clutches that have to make smoothly.
texasoil
'94 Infiniti Q45A
If you have chatter/shudder on a shift, you should add a pint bottle of LUBE GUARD (the RED bottle) to your transmission fluid. It will eleminate the chatter/shudder. Lube Guard is absolutely the BEST lubricant for clutches that have to make smoothly.
5seryan
Got the ATF changed. Runs like a champ. Maybe ill thought some lube guard in just for the hell of it.
PalmerWMD
Car: 2004 350Z
92 Q45 broke at 75kremanned transmission broke at 100k apprently due to clogged factory heat exchanger.
New transmission got transmission cooler rite at install.
5seryan
IF mine goes that fast. those dudes who did mine better go into hiding. cus i will bring my wrath upon them.
