Hey thank you for the help! It doesn’t drive any differently when shifting manually, it still won’t shift out of first no matter what I try with it. It’s been doing it for about the past 5 months, but the speed sensor is broken so I can’t tell how many miles I’ve put on. I haven’t had the funds until recently to do anything about it. The car has about 150k on the dash, it throws the AT check light once in a while, it flashes when I turn on the car for a few seconds. It has a check engine light but it seems to be for issues unrelated to anything involving the transmission. They’re things like a misfire and an 02 sensor, high idle rpm, faulty fuel level sensor. It’s also got an abs light and the tcs or whatever Infiniti’s traction control system, I think it’s vdc but I can’t remember, that light is on too, but that would just be a sensor. Ya the car has a lot of problems, but I like to keep my hands full so I’m never bored haha.EdBwoy wrote: ↑Mon Jan 29, 2018 11:26 amDoes it behave any differently if you try to drive the car in manual mode?
How many miles are on your odometer currently, and how many miles had it been slipping for?
You're right, you do not have a CVT. You have a conventional automatic transmission with planetary gears.
If you're looking for solenoids, those will mostly be in the valvebody... which will require some disassembly.
Either way you cut it, this isn't going to be painless.
If you've had any lights pop up on your instrument cluster, it would be good to know which ones they are. Have your car scanned, even if it isn't throwing any check engine light as there might be codes that will help point us in the right direction.
Hey thank you for the help! Yes the speed sensor is broken, the speedometer doesn’t work, and I hooked an obdII up to the car and it didn’t show any speed while I was driving, and also no miles are being added to the odometer, so the speed sensor is broken. Could that really cause slipping and no shifting though? Seems like an extreme problem for such a small thing. But I’ll look into the manual.04pathse wrote: ↑Mon Jan 29, 2018 11:28 amWell if you look in the FSM on page 67, it lists one of the potential causes could be a faulty speed sensor.
http://www.nicoclub.com/service-manual? ... 004_Q45/at
YES! the FSM says a faulty speed sensor will cause the vehicle to stay in 1st gear so, YES!InfinitiQ45F50Owner wrote: ↑Wed Jan 31, 2018 8:14 amYes the speed sensor is broken, the speedometer doesn’t work, and I hooked an obdII up to the car and it didn’t show any speed while I was driving, and also no miles are being added to the odometer, so the speed sensor is broken. Could that really cause slipping and no shifting though? Seems like an extreme problem for such a small thing. But I’ll look into the manual.04pathse wrote: ↑Mon Jan 29, 2018 11:28 amWell if you look in the FSM on page 67, it lists one of the potential causes could be a faulty speed sensor.
But here’s the thing, it used to shift when the speed sensor wasn’t working, but then one day randomly stopped.04pathse wrote: ↑Wed Jan 31, 2018 9:18 amYES! the FSM says a faulty speed sensor will cause the vehicle to stay in 1st gear so, YES!InfinitiQ45F50Owner wrote: ↑Wed Jan 31, 2018 8:14 am
It makes perfect sense to me, the speed sensor basically tells the transmission when to shift gears, when the speed sensor isn't working, it can't tell the transmission when to shift gears so therefore it will just stay in 1st gear!!
