Q45 Transmission capacity
timatt
I am getting ready to do a transmission flush/screen replacement on my '91 Q45. Does anyone know the capacity of the transmission? How much Mobil ! should I buy?
Thanx
timatt
DougQ45
Car: Q45, porsche 928 S 5 speed
about 14-15 quarts, although I beleive the capacity is around 11 quarts. you will need the extra to top off after the pan drop.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Or just to complete the flush if you pan drop first.
Q45tech
When you do a 3-4 quart pan drop use conventional to fill it back up prior to the flush no need wasting. expensive Mobil 1.
timatt
OK I'm a little confused, so could someone outline the protocol for performing a transmission flush? I tried a search, but could find nothing definitive.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Hmm, you couldnt find anyhting, Rex where are you???
This is the way you do it...
Pan drop/clean, filter change, then go do the flush.....
