mpetrilla »
https://forums.nicoclub.com/mpetrilla-u76413.html
Fri Sep 28, 2007 5:30 pm
Hello again. This really is one of the best car clubs on web - you guys answer quickly and obviously know a lot about these Infinitis. The D code that comes up just tells me my battery was disconnected but the transmission is doing something bad and that can't be the answer. Am i suppose to be counting the light beeps when I'm performing the code or just wait for the computer to do its thing and then spit out the code D and that's it?
What happens is this: cold car - starts up fine, put in drive or reverse - feels fine, drives down road normally to about 100 - 200 yards, but doesn't seem to want to come out of second gear. It begins to slip loke and rpms go up but car not moving proper speed until finally just sits there despite giving gas. Reverse doesn't work either. Turn off ignition, wait maybe15 secs, turn back on and can go another 50- 100 yards and dies again. Can repeat again and does same, etc, etc. etc. Limps on home - don't believe it ever gets out of first gear though after that initial first 200 yard drive.
I have new fluid, filter, trans cooler, in line filter- car had all that done 4-5 months ago and was driving fine for maybe 3 -499 miles worth. I'm selling it and wasn't driving much with it. Any help would be once again greatly appreciated.
Matt P
(Cleaned it up a bit for you, Matt - you're more likely to get a good response if you make it easier to read - capital letters and paragraphs and sentences and such. 96Qowner)
