locoluna825 »
https://forums.nicoclub.com/locoluna825-u93365.html
Fri Jun 01, 2012 1:11 am
I am having the exact same issue with a friend’s car. Series 1 rb25det, I did the harness. Its been throwing a TPS circuit code. I checked all of the same items above as the OP, I get 5v power, ground but no signal coming out of the TPS sensor. I’ve opened the wiring harness twice now, checked continuity of the wires, and triple checked the pining, I cannot get any signal out of the TPS sensor on his car. We tried 3 different TPS sensors. I can plug each of those 3 TPS sensors into my harness on my rb20det and get a signal out of each one. But cant get a damn signal out of any of them on his. It just also recently threw a Temp sensor circuit code.
On the series 1 rb25det and rb20det's the ground for the TPS sensor and temp sensors are joined together down near the ECU in the wiring. The only thing I have not tried was unplugging the temp sensor to see if I still get a ground to the TPS. (Since I think it would be grounding back up through the temp sensor on the manifold), and actually opening the ECU up to check for some sort of apparent damage to the board or components. This leads me to believe there is some sort of problem within the ECU grounding the sensors since it is now throwing both those codes and they share that ground from pin 30.
