oldmako »
https://forums.nicoclub.com/oldmako-u82911.html
Mon Apr 28, 2008 4:40 pm
If the wheels are fairly true, the tires in good shape and freshly balanced then perhaps you have a bad bearing (??) On old style bearings wobble at sped was indicative of wear. Replacement was cheap and easy and often solved the problem. These mothers are a different animal. I have not done a set, but from looking at the FSM they require a press to be removed and reinstalled, so a bit more of a job than simple cone bearings.
I've never done a set and I'm just tossing this out as something to consider. Take some time and do a search...you may find some additional info.
Good luck and let us know what the culprit was.
