What is the timing for my 96 (obdII) Q45? Is it able to be adjusted? My car is making that gurgling sound at initial throttle like the timing is out. Thanks for your help. Mark
Mark86T wrote:What is the timing for my 96 (obdII) Q45? Is it able to be adjusted? My car is making that gurgling sound at initial throttle like the timing is out. Thanks for your help. Mark
if that gurgling sound is coming from the dash area and sounds like water,check your cooling system for proper fill level,common condition! the timing is 15 degrees.check with timing light.
No it is not from the dash. It's from the engine bay & only occurs when you hit initial throttle. It goes away imediately though. It's only during initial throttle. Everytime.
