DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Sun May 18, 2003 10:05 am
The clicking is the cams snapping forward when the cam lobes pass their apex on the lifter. The valve spring is forcing the camshafts to rotate ahead of the crankshaft. Depending on which cam is rolling forward, you'll develop slack at different points along the chain. I think the noisiest clicking comes from taking out the slack that develops between the camshafts, when the driver's side cam snaps forward. If the pistons and valves were hitting, the crankshaft would come to a dead stop as you turned it (slowly and carefully of course). Not much noise though.
Wow, if you were wearing into the "finger" on the front cover, your chain was pretty loose! I assume you replaced the tensioners.
