landtodd »
https://forums.nicoclub.com/landtodd-u258.html
Fri Jan 03, 2003 8:58 am
Q45ver --
Ah, Vancouver. Beautiful area. Ah, a gen-1 Q with 30K. Hmmm . . . I'm jealous.
This was the car that was a Japanese exec's, and it just sat waiting for him in LA, right?
So, you're not driving it until you get the guides done? I understand and appreciate your caution with such a rare example. I hope no one starts talking about "over-investing" in this one! But then again, you bought it for a driver, right? Me, if I let my car sit more than a couple of days, the HLAs give up an annoying clatter on startup. Of course, for my car, 30K is a dim memory. Time to step up the oil-change schedule. Long and short of it, Qs like to be driven, and they seem happiest when they're driven a lot.
My feeling about the guides -- if your guy hasn't done this specific job before, you'll do just as well as he will. It's a great learning experience, probably a piece of cake for someone of your apparent talent, lots more fun than the under-plenum hose replacement. As you know, the only "special" tool you need is something that will remove/replace the 30mm crank pulley with 275 ft-lb. I cheated with my wonderful, magical impact gun, but more cautious heads really ought to prevail.
I don't recall whether or not you shopped the guide job with your first Q. My experience suggests you may have trouble finding someone to do the guides while leaving the chains in-place and un-replaced. Since guide-replacement isn't in their flat-rate book, everywhere I went, they found the closest job (the one they thought would get them close to the guides), which is replacing the chains. Then, four out of five said the guides couldn't be replaced without replacing the chains, which is (pick one or more) disinformation, ignorance, or salesmanship. Can't blame 'em. They just don't know . . .
As I recall, doing the guides without replacing the chains is a T3 innovation, the details of which Dennis graciously shared with us. All hail T3. And many thanks to Dennis.
