Q45 throttle body
ryanbor
Car: rb25 swapped 98 e36
Hi everyone,
I am curious as to if anyone knows if all generations of the q45 came with the same throttle body even if the engines were different.
Thank,
Ryan
Q451990
:welcome: to NICO!
90-96 are essentially the same... 90mm outside diameter. After 94 or 95 the design of the TPS sensor and sub sensor were slightly different. 97-01 are smaller cable driven units... after that they were servo driven drive-by-wire setups.
Heath
ryanbor
Great thank you! I am mounting it onto my greddy style intake for and rb25, there for just need to know if they all mount the same as i know some will bolt right on.
Thanks!
Ryan
Q451990
Absolutely - they all have the same bolt pattern and opening 90-96.
Heath
ryanbor
Just so that im clear every q45 throttle body has the same bolt pattern and up to 96 is 90mm and after is smaller, same bolt patern?
Thanks,
Ryan
Q451990
90-96 all have the same bore and bolt pattern. After that they're substantially smaller and may have a different bolt pattern. Not sure on the bolt pattern for sure though.
If you're shopping for one, keep in mind that the TCS versions had a different design, because a secondary throttle body bolted on to the primary one. So it's not that easy to hook an intake tube up to a TCS version. They would still have the same bolt pattern where it connects to the intake though...
Heath
