If your goal was to come across like an arrogant jerk...well you nailed it.SeanC wrote:Q45 TPS Specs:With throttle valve fully open, 4.4-4.6 volts. With throttle valve partially open, .4-.4.6 volts. With throttle valve fully closed, more than .4 volts.240sx TPS Specs:If the voltage is between 0.45 - 0.55 VDC at idle, the sensor is adjusted properly.OMG at with the throttle completely closed they are exactly the same! And guess what when you full open it the 240sx’s throttle body is going to be at 4.5 volts OMFG! There is so much crap information here I had to fix it all. The TPS voltages are exactly the same. Also you will not loose throttle resolution. We are not altering maps in the ecu here people. You will also not loose any power any where. Once you start adding more air via turbo, supercharger or even big cams you will want a bigger throttle body so you can take advantage of it. Remember the less restrictions the better ;-) just like exhaust (don’t get me started on the back pressure debate here)
What there saying is you will loose a lot of partial throttle control especially on a boosted car.. a cracked q45 throttle body will probably flow as much as a 25-30% open ka throttle body but when you get to the upper end near WOT the throttle body is no longer the restricting factor... the stock intake manifold will be. I would say that with the q45 throttle body on the stock intake manifold from 70% throttle to WOT there will actually be little to no increase in airflow (making the pedal feel numb) unless you have a VERY powerful motor with head work and cams etc and the stock manifold flows better then i am thinking it does.SeanC wrote:Q45 TPS Specs:With throttle valve fully open, 4.4-4.6 volts. With throttle valve partially open, .4-.4.6 volts. With throttle valve fully closed, more than .4 volts.240sx TPS Specs:If the voltage is between 0.45 - 0.55 VDC at idle, the sensor is adjusted properly.OMG at with the throttle completely closed they are exactly the same! And guess what when you full open it the 240sx’s throttle body is going to be at 4.5 volts OMFG! There is so much crap information here I had to fix it all. The TPS voltages are exactly the same. Also you will not loose throttle resolution. We are not altering maps in the ecu here people. You will also not loose any power any where. Once you start adding more air via turbo, supercharger or even big cams you will want a bigger throttle body so you can take advantage of it. Remember the less restrictions the better ;-) just like exhaust (don’t get me started on the back pressure debate here)
