Hello nico family, I've been away for a while but I'm back again.
Recently I picked up a 98 Nissan stagea rs4 with a s2 rb25
I installed a foward facing intake plenum, q45 throttle body, gt3582r, too mount manifold and fmic.
I retained the factory injectors, ecu, maf to start the car up and move it around untill I can buy a new clutch.
Now I notice on the s2 rb25 throttle body there are two sets of plug ins on the throttle body, the q45 throttle body has two as well. I hooked up my test light on the Rb side of the harness and found that only one of the plugs gets power. That's the one I wired into the q45 throttle body (red, black, white) and it's running dam pig rich now. Even if I totally disconnect the Tps. I can read it's sending the correct voltage at closed and wot yet it's still pig rich, any one else run into this issue or have a diagram for a q45 throttle body wiring on a s2 rb25?
Thanks, tom
