Q45 Techs/Experts look here
oxs1
Im planning on putting a leaf blower on my intake. Need some advice on this. How much cfm to make 4 psi. Is a leaf blower capable of this kind of boost on the Q?
Hoo boy.
Should I just delete this now, or are you ready to face the flames? :)
This one's been discussed - search "leaf blower"...
rsiwicki
Car: 95 Q45T
is this a joke or are you serious??? I have never heard of such a thing but if it works....all the better and probably cheaper than my $2,600(excluding rental car) headers that I just had built.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
AZhitman wrote:Hoo boy.
You're kidding, right? Really? Wake up, it's just a bad dream.
1qckser
Car: my wife, daughter, q45T,G20T,SE-R
I got a 5hp Toro gas leaf blower I will sell ya:D
qship96
Car: 1996 Infiniti Q45
why not just buy the Tornado,improves gas mileage,and must add--30-50 horsepower at least!!!!
911/Q45
Car: 1990 Infiniti Q45
1996 Porsche Turbo
Send money to me in Nigeria, millions of horsepower will be your's for the taking!
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
that i know of, a leaf blower only blows. think of it as a normal fan. a turbo or supercharger is an air compressor. that is where the intake pressure comes from. since the leaf blower is just basically a fan, it won't have all that much power to compress the air nor the design to compress the air.
my statement could be flawed but i'm pretty sure it is correct.
Very correct.
There are other issues as well, such as additional alternator drain, wiring, the inherent heating of air by increasing the velocity, etc...
Electric blower will not even increase 1 psi.
mtcookson
1992 Iinfiniti Q45
and much much more
well since the leaf blower is gas powered (at least i'm assuming so) you won't have to worry about alternator drain nor any power drain at all since its power is fully independent. now if it were electric you would need to run a power inverter so that you could supply the 120 volts ac or whatever voltage it would be (i'm not too knowledgeable on home electricity).
DAEDALUS
How much power does a supercharger consume to create 4 psi? If it's more than what the aux engine puts out, then forget it, cause the aux engine won't be as efficient.
Q45tech
An Eaton supercharger can consume 25 HP to create 6 psi and 500 CFM...........radials are around a third less.
As an example a homemade flow bench with a gigantic shop vac can move 300 CFM with less than a psi of vacuum [= boost].
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Can we have a reposession on this car...
LEAF BLOWER... Must ..... refrain... comments...
MiniMan
Leaf blowers are designed for blowing leaves... that and mounting on $500 or less cars for highschool projects. NOT for mounting on a $5k car! There are so many reasons not to follow through with this. Buy the headers and an ECU/TCU instead.
Corey
...or the catback which is now available. :)
oxs1
Ok guys to all of you who are fuking being b1tchs fuk you and to all the guys who are not thanks for telling me this wont work. Sorry i asked this stupid question.
911/Q45
1996 Porsche Turbo
Told us didn't he!
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Wow, it wasn't a joke!
mtcookson
1992 Iinfiniti Q45
and much much more
if you know how to set up different gear ratios and had a powerful dc electric motor you could get a turbo, take the turbine off and the turbine wheel. Get someone to machine a gear with a sleeve on it so that you can keep the shaft in the turbo by using the stock nut that goes on the shaft.
| | | | | | <- gear...|| || <- sleeve...|| ||..../\.... | shaft(don't mind the dots)
Make a sort of gear box that will bolt onto the center section to contain your gears for some lube. Make the box to where you can slip the shaft of the motor in and bolt it on. Have a gear machined to fit the electric motor and the figuring out the gear ratios so that you can spin the shaft at around 100,000 rpm (that will be one crazy gear ratio depending on how fast the electric motor runs). The gearing will be pretty crazy because even if you got an electric motor that produces max power at 10,000 rpm you're gearing would need to be 10 revolutions of the impeller to one of the motor (if I'm thinking it through correctly). You'd have to do some math to figure out the best gear ratios per the speed of the motor at maximum power and what not.
With this setup, you'll have the instant boost off the line like a roots style s/c due to the electric motor's crazy instant torque but also have full boost throughout the rev range kind of like a turbo. Depending on the power output of the motor you get you would most likely have to upgrade your alternator but it would be a sweet setup nonetheless.
I just now thought of it because I got bored and had nothing else to do. :D
Highway Q45
Car: Auto-X, Porsche 944's, woodworking, GreaseSlinger
Remember the GT car several years ago with the 4-leafblowers motors that would suck trapped air from beneath the ground effects. They worked with the speed/brake activated spoiler. That thing would flat out hug the ground with a mild vacuum. The concept was immediately outlawed. Now if I can find a good use for that yard waste shredder.
mtcookson
1992 Iinfiniti Q45
and much much more
I believe the Ferrari F40 or F50 actually uses the radiator fans as a downforce mechanism. Those large spaces in the hood are for air passage ways to the radiator fans. Pretty damn cool if you ask me. :D
MiniMan
Highway Q45 wrote:Remember the GT car several years ago with the 4-leafblowers motors that would suck trapped air from beneath the ground effects. They worked with the speed/brake activated spoiler. That thing would flat out hug the ground with a mild vacuum. The concept was immediately outlawed. Now if I can find a good use for that yard waste shredder.
Dude, what a SICK car. I'm in awe...
Imagine if you had a throttle sensor which activated a belt driven blower that sucked air from underneath the front of the car while the same throttle sensor activated a leaf blowing motor (connected to ducts of course) in the trunk...
Why can't we have a couple millionaires on these boards? Damn people, go waste some of that money!
Corey
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
mtcookson wrote:I believe the Ferrari F40 or F50 actually uses the radiator fans as a downforce mechanism. Those large spaces in the hood are for air passage ways to the radiator fans. Pretty damn cool if you ask me. :D
And unworkable, I'll bet. No way to suck enough air through a radiator to generate downforce.
Jim Hall did it on his Can-Am (now their was a great racing series!) Car (the Chapparal 2f?) by mounting an extra engine (V2, I think) to power a large fan to evacuate air under the car. It was outlawed before the auxiliary engine had a chance to fail in a corner and send the driver to certain death when his downforce disappeared. It was essentially the world's first (and still the fastest) parking lot/roadway vacuumer.
Highway Q45
maxnix wrote:Jim Hall did it on his Can-Am (now their was a great racing series!) Car (the Chapparal 2f?) by mounting an extra engine (V2, I think) to power a large fan to evacuate air under the car. It was outlawed before the auxiliary engine had a chance to fail in a corner and send the driver to certain death when his downforce disappeared. It was essentially the world's first (and still the fastest) parking lot/roadway vacuumer.
Good memory you have, I couldn't even remember what type of car it was on. It was a gas to watch that thing approach a turn at an incredible speed and then scrub all that momentum in a split second; between the brakes, the spoiler, and the Hoover it was an amazing choreography while it lasted.
