elwesso wrote:Remember that for PS and ATF theres a way you can do it at home with no equipment and get the same results!!!! Drain/refill etc...
I think you've been smoking something, Wes.
If you want to waste ATF, multiple drain and fills will get you close to what one mechanical exchange will, but detritus in the planetary gears and TC won't go anywhaere because there is no pressure.
Turkey basters will work for the PS, but what is nice about the Sun machine (and I presuem the BG one also) is that feed is continous with extraction, so no air and no fluid starvation. On a $1,100 OEM rack, that is assuring for me.
