Q45 TCS and SLIP lights are on
roughyear
my 94 Q45a thas had the slip and tcs lights on for a year now. i figured it was the two (2) relay switches near the battery which were bad so i replaced them... BUT the lights are STILL on!!! am i doing something wrong or is there another problem with the traction control???
Q_SHIP
Car: 1999 Q45T with a billion miles.
Mine also. The "Trac off light" is always on and 2 minutes after the car running, the "slip light" comes on and stays on. The system works before the "slip light" comes on. Do you have the same symptoms?
roughyear
both of my lights stay on the whole time!!
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
You need to check your TCS control unit codes!! check the FSM!
roughyear
"You need to check your TCS control unit codes!! check the FSM!"
how do you check the TCS control unit codes???? what would they say or otherwise implicate other than bad relays??? .... i don't have an FSM manual
thanks
elwesso
2007 BMW M Coupe
Well sir, you need to email me.....
We can make that happen... [email protected].....
