Q45
biglil
Car: 98 q45
My ABS TCS SLIP light is on and I don't know what is the problem, can someone please help me.
estil0
Car: 92 Q45
If the battery is over 3 years old, replace it.Check and see if there is any corrosion on the tray that may be affecting the tcs relays (blue relays connected to prong coming from battery tray, at least thats how it is on my '92)Test the alternator, common symptoms for bad alt.Or your tcs unit in the trunk may be bad, you'll have to look up how to check it.
estil0
Car: 92 Q45
Actually, here you are.
zerothread/217450
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
If it turns out that that's does'nt fix it you can also try this:
By: Wes Stinson
Use this procedure to see what is causing your "SLIP" and "TCS OFF" lights to come on. The TCS control unit is located under the rear package shelf, in between the left rear speaker and the "box" that sits on the rear shelf. The aforementioned LED must be viewed from the trunk side, it is easiest to remove the divider. Best use a dyno to do this cause it safer than jacking up the rear wheels.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Alternator and battery are probably both on the fritz.
There is a TSB on the alternator that is VIN specific.
Also please observe the stickies at the top of the Forum, particularly.
From here out, please use more descriptive thread titles!
That's the only way information posted within any thread is searchable.
Mint Q45A
Car: 1994 Q45A
You may want to check the relay on the ABS actuator (black box, close to the firewall on the passenger side). Do you hear the relay "buzzing" after you shut the car off?
