FIXED Q45 suspension control module
daniel.b
Hi I'm an Auto Electrician in the UK and I've been asked to look at a Japanese import Infiniti q45. It has hydraulic suspension but little is known about it. The car is thought to be a "factory drift spec model". The module in the photo was damaged and now when the engine is started it only raises the left hand side even without the module connected. I'm not sure if this module is a standard part and just wondered if anyone could help. The only markings are "Data Series" and a serial number. I've flipped the image for clarity.
Thanks,
Dan
goody90q45
Car: 1992 Infiniti Q45 (sold)
That doesn't look like an OEM active suspension controller. The pic below is of an OEM unit and it's mounted under the rear parcel shelf above the gas tank.
daniel.b
A quick update to close the thread. I pulled the adapter out of the wiring loom in the boot today and just plugged the factory loom into the factory ecu and the car is now fine.
Thanks,
Dan
