With no maintenance history, we can only guess.RickyQ45AZ wrote:1.) It was running fine, but smelled rich out of the exhaust, then failed emissions (like I said).
2.) I took it home and changed the oil, and installed a K&N air filter.
3.) Still on the jack stands, I tried to start it to circulate oil for a few minutes to check level on the dipstick (being new to the Q, I didn't know how much oil it would take).
4.) I changed the spark plugs & pcv valve.
5.) I'm really loving the car!
I tried that website that offers the OM's and TSB's. I couldn't find the OM for my year. Or G50's in particular.maxnix wrote:With no maintenance history, we can only guess.
1.) Bad O ring on an injector? Have you removed any of them?
2.) Lose the K&N. Known (to those who have read the previous posts) to be an MAF killer. OEM paper is best and least expensive.
3.) Why don't you download an OM and an FSM? They are free. TSB cost a one day subscription,
4.) Using OEM specified parts only, of course!
5.) Wait until you learn how to restore it to as new OEM condition.
http://www.nissan-techinfo.com...id=54Haitian_King wrote:I tried that website that offers the OM's and TSB's. I couldn't find the OM for my year. Or G50's in particular.
I'll quote it again for emphasis.Q45tech wrote:The 3,000 rpm stumble is a clue that one of the 2 connections to CAS or MAF maybe defective, corroded, or intermitent.
The FSM points [read fine print] out various safety limits preset in ecu like 2,000 or 3,000 rpm
Did you check your ECU codes? 90-93 are known a little more to have funky connections especially at the CAS.Q45tech wrote:The 3,000 rpm stumble is a clue that one of the 2 connections to CAS or MAF maybe defective, corroded, or intermitent.
It looks like they stopped at 96. That wouldn't do me much good because it's OBDII right?maxnix wrote:http://www.nissan-techinfo.com...id=54
A few of the comfort and convenience features will not apply, but OBD II does not have a large impact on other operational functions.Haitian_King wrote:
My Q wouldn't pass smog when the pump was bad so I had to pass it the other way. Most recent smog the fuel pump was replaced and it passed just fine perfectly legal.Q45tech wrote:Never seen a bad Q fuel pump cause a failing of emissions, IF it can allow engine to reach 2,000 rpm.
You too?Kiven422 wrote:
Hah - I still have Microsoft Word for MS-DOS on 6 floppy disks.
CAS is Crank Angle Sensor, but Nissan calls it CPS, Cam Position Sensor. The CAS connector, along with the MAF connector, is known to get corroded and cause trouble. Pull the connector and take a look - clean it up and apply some dielectric grease. It may be your problem - cheap n easy.RickyQ45AZ wrote: I don't know what a CAS is, but am considering replacing the costly egr valve before I go back to emissions testing center. Thanks again.
