q45 steering problem
ca18detdrift
Car: 89 240sx
in between about 45 degrees of the steering wheel right dead in the middle, when i turn the car doesnt move at all. so in other words, to move the car just a little whole going straight, i would have to turn the steering wheel about 45+ degrees for the car to even move. and another thing, when im going straight, the steering wheel is crooked to either side, depends on which turn i just made, and when i just made a turn with my turn signal on, the turn signal stays on after the turn and doesnt turn off like its supposed to. would anyone know what the problem could be? im thinking the steering rack is bad, but im not really sure. if anyone could help that would be great. thanks alot.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
What do your fluid and steering rack seals look like? Ever replaced the steering rack bushings? Any maintenance? How about your steering links? Rest of the suspension up to OEM standards?
Modified by maxnix at 9:06 AM 12/21/2005
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
That sounds just like steering rack bushings.....
Q451990
I'd say it's definately time to check out the rack bushings, the u-joint that connects the steering column to the rack, and everything else steering related. It sounds like a serious issue - to the extent I would be afraid to drive it until finding the problem!
Heath
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
If the steering is that bad, then the suspension is probably in poor shape as well.
Try this:
New StrutsNew dust bootsNew strut mountsNew bump stopsNew upper linksNew sway bar bushingsNew tie rodsNew rack
This should take care of your suspension and steering woes. I bet your tires will last much longer, too.
DrewQ45
Car: 1990 Infiniti Q45
ca18detdrift wrote: i would have to turn the steering wheel about 45+ degrees for the car to even move.
Get this fixed and stop driving it till you do... If you insist on driving it... lets have a little talk about your will... oh and you might as well pick one out from now.... They're having an Xmas sale....
http://www.casketsonline.com/
RobertsnewQ
No sh*t. ALso tell us where you live so we know not to drive near you!
kouki_monstor
Car: '92 180sx
lol thanks everyone. do u know about how much it would cost for repairs if i was to get parts and install it on my own?
kouki_monstor
Car: '92 180sx
bump...
Q45tech
If the problem is just the rack sliding in its hold down mount isolators [bushings] .......the 2 are cheap like under $30 and a few hours work.
Very common problem solution, usually resulting from PS fluid leaking on the rubber bushings from a PS hose leak........fixing that leak will cost more in parts.
Old cars need all rubber parts/hoses replaced at least once at around 10 years some every 6 years and the multiple of 6.
Just part of $3,000 [at dealer prices] annual maintenance to keep things near new. Just because you don't spend all of it doesn't mean it doesn't accure.
Raxephon
Car: '04 RX8...for the moment...
Easiest thing is to check and see if its the column or the rack.
Turn the steering wheel and see if it keeps pace with the lower joint at the rack. (You'll need a friends help on this one)
(Also, lower joint is what connects the column to the rack)
If the steering wheel turns but the lower joint doesn't, then its probably the column.
If steering wheel turns and the lower joint keeps pace, then its time to take a long hard look at the rack.
Either way, you need to park her & fix her before its too late.
Modified by anlasak at 9:21 AM 12/24/2005
Raxephon
Lower Joint &The insulators (bushings) that Q45tech was mentioning.
Modified by anlasak at 9:20 AM 12/24/2005
