Q45 Starting Issue
ebonyq45
Hey everyone I’m new to the forum and was wondering if anyone have an answer for the issue I’m starting to have. I have a 2002 Q45 and I’m starting to have a little starting issue with it. I have had to turn the key a few times before the engine would turn over. All the accessories will come on but the motor will not crank until the 3rd or 4th try, any ideas?
djwarner
Car: 1971 240Z Series I
2006 350Z
I'm by no means a mechanic but here's a list to check:
Battery cranking amps
starting relay
brake switch
park/neutral switch
starter/solenoid
ebonyq45
I've check everything except the starter solenoid and relay, so I will check them out. Thanks.
q45ness
Car: 1994 Q45
Please be sure your battery terminal posts are clean/tight....
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
q45ness wrote:Please be sure your battery terminal posts are clean/tight....
In addition to the above, make sure the battery voltage is 12.5 VDC or higher. You may have a weak battery that needs replacement. A fully charged battery must have >12.6VDC.
ebonyq45
Thanks everyone, I think is was the battery.
