Q45 stalls when braking suddenly
Ratardid
Car: Infinity Q45t
I'm wondering if any one can tell me why my Q45 would stall when I have to brake suddenly. It has only happened a few times in the last 4 or so months, but I think it is becoming more frequent. I'm worried that it will get to the point that it stalls every time I brake. Any ideas?PS It's not my fault I'm having to brake suddenly, it's the other drivers!
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
I think its the MAF Sensor read this: zerothread?id=102297, http://q45.org/maf.html and while you have the air box off you might as well clean the throttle body: http://q45.org/tbclean.html easier if you don't have TCS like me, I am screwed I am not doing my main TB till I have to take off the plenum and hopefully thats not for another two years.
96Qowner
Car: 1996 Q45
Also check your transmission fluid level. A low level can cause the torque converter to lock up and stall the engine when you brake.
Actually, I think your cause is more likely to be transmission/TC than MAF.
Ratardid
Car: Infinity Q45t
Thanks for your help. I'm so gald it was a problem that was so easy to fix.Now, I'll find out if it really worked, as I take an 1800 mile road trip with two 17 year olds.
dormicum
Car: 2002 Q45
Ratardid wrote:Thanks for your help. I'm so gald it was a problem that was so easy to fix.Now, I'll find out if it really worked, as I take an 1800 mile road trip with two 17 year olds.
really fixed????????what did you do for make it OK?????????as my preious Y33 had the same problem
