maddieQ wrote:I have TCS. I dont know anybody locally who drives a Q45. Do any of the Q owners meet regularly someplace sometime to exchange Q talks? also which is the best place to buy a new MAF?
Sorry for these questions I'm a newbie thanks,
The MAF is spendy... you might want to try this 1st...
Every year after the ethonal is removed from our gas here in New Mexico My Q45a (and my old 93) starts bucking like its a RODEO or some S**t..Idle is rough and low power (for a Q that is)
Heres what I do:
1) Drive to AutoZone (or anyparts place that sells TECHRON)Buy 2 of the 12 gallons of TECHRON fuel treatmentsand one 20 gallon of TECHRON Fuel injector treatment and 2 x 16oz bottle of MM fluid (Marvel Mystery Oil 2.99 each)
2) Empty the fuel tank (by driving).
3) Drive to Chevron and buy 5 Gallons of 91+ octain.
4) Add the 2 bottles of 12 gallon treatment(yes both bottles!) and one whole 16 oz of MM fluid
5 Drive the Hell (gas) out of your Q45!!!
6) Drive to Shell and get 10 gallons of V-Power 91+
7) Add the 20 Gallon treatment and another 16 oz of MM fluid.
8) Drive it(like you stole it)!
This works wonders for me..
Some poeple use BG treatment... Tried it once and didn't fair as well as the Techron..
Try it!!
Its like 34+ for of the cleaning fluids (not the gas though)
Also there is a lot of talk of Acetone in the tank.... IT WORKS...my car is alot more powerful, smooooother idel and my MPG went up from 13 MPG to 17MPG so far...
I still need a new air filter then I bet I hit atleast 20MPG...
If it is still that bad then you have a vacum leak or a bad connection in the system
It happens when a shop agrees to work on a Q45 but is not familar with it...
My friend carl took his car to "Infinity Auto" (not to be confused with Infiniti with a "I") in the bay area and the 95 Q45 got more F**ked up each time they "tried to fix it"..
He then took it to the Dealership (which I try to NEVER advise) and they plugged it in to the CONSULT (Nissan OEM computer) and they found the issue right away..
"Infinity Auto" left two connectors unplugged!!!
