q45 speedo question plus remote entry help
spamdoggy
Car: 1994 infiniti q45
Hello Everyone,
I have a 94 Q45 with 75,000 some odd miles on it. Recently the odometer stopped working all the time. The trip odometer (digital) still works as normal but the analog odometer in the speedo gauge quit only works about half the time. Sometimes it will count, and other times it doesn't move.Does anyone know what could be the problem and if I can fix it. If not, can you tell me what years the speedo's were the same so I can replace it with a used one (on ebay there are a few from '91 Q45's that I could pick up cheap if they will replace the one I have). I figured I could open the new used speedo and steal parts, or just reset the new used one to the mileage my original says and install it in place of the old one.
Also, just got a new remote entry fob for my car and need to know how to program it into the car so it works.
email me if you have info: [email protected]
Thanks in advance for any help you can give.Spamdog
P.S. I'm also having a loud hum coming from behind the back seat. I'm guessing the fuel pump is making it. Does this mean it's going bad and should be replaced, or is there an adjustment that can be made to help. It's been doing it for quite awhile and doesn't seem to cause any problems other than the noise.
Modified by spamdoggy at 6:29 PM 1/12/2005
rsiwicki
Car: 95 Q45T
all your questions and them some can be found here which provides links back into this website for details....if that makes any sense
http://www.q45.org/techhelp.html
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
THe odometers sometimes fail on the Qs... I have a used instrument cluster from a 94 id sell.. Just roll the miles back to where you are...... The 9093 and 94+ are not interchangeable...
your fuel pump is going bad..... REPLACE ASAP!
spamdoggy
Thanks for your help everyone. You guys are a great resource.I will be doing some work it looks like.
One of you guys said you have a used 94 speedo that I could buy.Drop me an email at
[email protected]
Thanks again
