Q45 Speakers
sachmo12345
Car: 1994 Infiniti Q45a
1995 Nissan Maxima SE
how does the whole bose replacment policy work, does anyone know the adress of where to send them or link me up to a helpful link..
Thanks
Rex
Car: None
Is this what you're looking for?
http://www.carstereohelp.com/infiniti.htm
Q451990
What year is your car? Only 91&92Q45s are part of the recall (I think) maybe that's what you're asking? Run a search for "Bose Amp" and you'll find several threads on this, including recall info and the phone number to call.
Heath
I always emphasize the $30 junkyard method. Buy a used amp, dig one out of a Maxima or a Mazda Millenia, get a 6-12 month typical junkyard warranty.
Q45tech
Each amplifier module has its own special equalization [frequency response and gain]. Bose made over 43 different amplifiers [each with over 20 differing values of resistors and capacitors [plus a different EQ IC]---- they look the same physically.........function of interior space and materials and how that attenuated mid/high frequencies and the tuned port for bass boost.
The front ones are quite different from the rears [in that the smaller front speaker and tuned enclosure are less efficient than the 6x9 rear.
Can't go haphazardly switching thing around if you expect the as new flat frequency response.
They spent a lot of engineering time picking the correct equalization..............unfortunately many non audiophiles want distorted excessive bass.
Without an acousitic spectrum analyser or at least a broadband sound level meter [measure plot and graph method].......and a frequency test tone tape or cd]........each human ear response is different and changes with age and exposure to [[drugs oxycotin Rush, X, Ice, etc*]] and sound intensity and duration.http://www.audiocontrol.com/te...1.pdfh ... si...s.htm
* since we probably have a wide and diverse audience here.http://www.rnid.org.uk/html/fa...s.htm
sachmo12345
i talked to AzHitman about and he said i could send in my speakers from a 1994 and for 100$ have them rebuilt or prolly just a new set
