Q45 spark plugs
1990_q
Car: 1991 Infiniti Q45
2005 Toyota Camry
I'm going to chang my spark plug, but cant find (NGK PFR5G-11) I found ( NGK G-Power Platinum-BKR5EGP) and
( NGK Laser Platinum- PFR5B-11), but are NGK and both are platinum. here's the link,
http://www.oreillyauto.com/site/c/searc ... NGK&mc=NGK
Please help...
OwnerCS
I use
NGK 2300 PFR5B-11 Double Platinum Spark Plug
The price at SparkPlugs.com seems high compared to the online dealers we recommend.
http://www.infinitipartsusa.com and
http://www.orderinfinitiparts.com
http://www.sparkplugs.com/Automotive-c1 ... l=Platinum
1990_q
2005 Toyota Camry
Whats the difference, there both NGK and platinum, but 1 is double platinum
OwnerCS
Double Platinum is the factory recommended.. Most long time owners on here use the NGK double platinum. I put some of the Iridiums on my Q when I first got it -- then soon afterward needed to reseal the valve covers (RTV), replace injectors, timing chain guides, hoses, knock sensors, and etc.
I figured since I was spending over $3,000 on parts to make everything under the plenum and around the engine like new, why let a few bucks on plugs stand in the way of having it be all original. So I went with the PFR5B-11. I found the online dealers (that are our sponsors) had the best deal over parts store prices.
Lokim
Car: 1994 Infiniti Q45 acquired 4/25/10 w/192K
Now at 222K and going strong!
www.rockauto.com
NGK # 2647 (PFR5G11) $9.76 ea. + shipping
1990_q
2005 Toyota Camry
I went to (pick your part) today and searched Q's, Maximas and J30's, and they had (NGK PFR5G-11) and
(NGK PFR6G-11), whats the difference and can I mismatch them...
mattd1979
Car: 1990 Pearl White Q45 plain Jane with 266,000 miles. 2015 moonlight white metallic Q70L with 20” wheels, sport brakes and a 5.6L at 58,000 miles.
5 is the hottest and 7 is the coldest heat range plug. Usually most times one would run a 6 for the heat range to be safe.
Here is a link to NGK.
Matt
http://www.ngksparkplugs.com/tech_suppo ... ugs/p2.asp
1990_q
2005 Toyota Camry
I bought 4 (NGK PFR5G-11) and 4 (NGK PFR6G-11), they are all in great shape and only cost me just under $6. Can I install these together...
Q451990
You bought used spark plugs? :gotme
1990_q
2005 Toyota Camry
Yes I did, and they are ALL in great condition...
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I wouldn't mix and match heat ranges. I think IoS prices are about $60 for a set of 8 which is unbeatable.
