Q451990 wrote:BTW, What's the grey wire and clear plastic thing in the lower left corner of the picture?
Thats the red 4 gauge power cable that goes back to the trunk for my 300watt amplifier, DVD/MP3 player, LCD screen and neon lighting network. I took the color out of the rest of the picture because that is what I wasn't focusing on....just the stuff in the colored area.
DAEDALUS wrote:I've had that happen and I completely forgot about it! Well, 2 months after doing the plugs, guess what? I started missing on the #2 cylinder. I may have caused some latent damage that got worse over time, leading to arcing on that coil. I replaced the #2 and #4 coils, and all is well.Do like Wes says. Put it all back together and start her up. If anything is wrong, you'll know where to look. Replacing the plugs is a real pain, but if you have to replace the #2 coil later, I promise it won't be too bad.
Well from everyone's suggestion I guess I should just go ahead, plug it all back in and start it up. It just worries me because there was a small shower of sparks with a POP sound when they touched....not a little static SNAP sound. Also....one of the bolts that hold the #6 cyl boot in place busted. Is it ok that the boots be held in place with 3 bolts instead of 4? Only the head of the bolt broke off.
