litton »
https://forums.nicoclub.com/litton-u29452.html
Mon Jun 06, 2005 11:28 am
The car:1992 Q45 with traction control, 155K miles. I just got it about two weeks ago as a graduation present. It was purchased on eBay. Unfortunately, that's all I know about its history.
Service history:The car has no service history. After purchase it was taken to a dealership, who replaced the steering rack U joint and boot. The service manager said to monitor the fuel pump, and that the following things are leaking: right power steering rack seal, turbine sensor, valve cover gaskets, and crank seal. Also, there is a note on the invoice that the power steering pump needs to be monitored.I have no idea whether the chain guides have been replaced. I asked the service manager, and he seemed unconcerned. I also asked my father, and he didn't think it would have lasted to 155k without them. As I have no practical experience with car maintenance, and I cannot remotely afford to have them replaced anyway, I drove the car, albeit nervously.
Trouble:Driving back from Boston (60 mile trip) last week, I noticed that I was having to press down more than normal on the gas pedal to keep up highway speed. After parking but before shutting the car off, the fuel pump was buzzing pretty loudly.
My lame attempt at fixing things:I ordered a new fuel pump. In the meantime, I also observed that the car idled almost silently when cold, but as it warmed up and the idle speed dropped to around 600-700 RPMs, it got loud and vibrated a little. After looking on this forum and q45.org, I decided that the easiest thing I could try would be cleaning the throttle body. I have extremely limited experience with mechanical things (and I didn't want to deal with getting new gaskets), so I just took off the air hose and sprayed throttle body cleaner inside, catching the runoff with a towel. I then reattatched the hose, and started the car.
Yikes!:When I started the car, because I am an idiot, I had my foot on the gas instead of the brake. The engine got up to about 6500 RPMs before I realized what I was doing and shut it off. I then restarted the car. It shook violently, and the RPMs bounced around. I shut it off again, thought for a minute, and cranked it several times, but it wouldn't start.
Afterwards:About eight hours later, I decided to try it again. It started, with some serious vibrations but not as bad as before. I let it run for about ten seconds, and then shut it off, satisfied that at least it wasn't dead. This morning I tried it again, and it started out the same, shaking at maybe 1100 RPM, then after about a minute it started to shake violently and the engine speed quickly dropped to 300 or so, then stalled.
I can't afford to take the car in for probably at least a month, so if anyone has any suggestions I could try before then, I would definitely appreciate it.
