sdkhalsa wrote:It is the rust red connector just to the left of center, middle of "y" coolant channel between the two head banks. If you look on LC-10, there are two engine temperature sensors. This is the one on top.
Actually there are 3 for the '94 Q45t, the normal 2, of which one has a blade connector,(that one is for the instrument cluster), and one that has 2 pins in a red plastic recepticle,(that goes directly to the ECU).
The third is located in the middle of the coolant crossover pipe that sits between the cylinder heads and just above the "X" crossbracing cast into the top of the block.(I do not know the exact reason for this third sensor since this is my first Traction model Q45, but it seems like a great place for an aftermarket coolant temperature sensor)
