Q45 Seat dying using Leatherique
silver2k2
Car: 1994 Q45 Ivory Quartz/Tan
Some have you have seen my pick and pull thread. I found a nice black leather passenger seat that I am going to dye and repurpose to the driver side. I will use this thread to document the process and results
Here is what I started with
I took apart the seat, and then covered it with leatherique leather rejuvinater to, and baked it next to my propane heater to open up the leather and accept the conditioner.
I then sanded the leather down with the preparation solution provided by leatherique. I didnt take a picture I will take one when I do the seat back
After letting it dry overnight I hung it up and began to paint
Air setup
A few runs, I will sand out before applying the second coat, this dye flows faster then auto paint so my material setting was too high, live and learn
Close up
Q451990
Wow!
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Great job.
But how hard was it to remove the leather cover from the foam?
silver2k2
The leather is still on the foam, I plan to swap the cushion and foam togther. If that doesnt work its just a matter of cutting hog rings and re attaching
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Looks like a surface treatment only, so I wonder how long it will last?
Very well done, though.
Infinitiguy19
How can you tell its only a surface treatment from the pictures?
goody90q45
Car: 1992 Infiniti Q45 (sold)
Looks great Jared.
Is this the same material you used to patch your tan seats or another product by Leatherique?
I was going to go to Pick n Pull Sunday and grab the active sway bar. Looks like I should have gone a couple of days earlier.
tkd_q45
Looks great! I'm assuming you used an air brush or spray gun of some sort? Also, I though one had to do the sanding before applying the leatherique in order to thoroughly soak in?
Did you send in a sample for match or did you provide a color code?
Also found a bunch of interior repair info/videos here:http://www.vinylproflash.com
Main product page for this company is here:http://www.vinylproleather.com/
Modified by tkd_q45 at 5:52 AM 1/19/2009
silver2k2
I did use a scotch bright pad when applying the conditioner
I used an HVLP mini gun to apply the dye
I sent in a color swatch from the bottom of my back seat and had a custom matched color made
silver2k2
maxnix wrote:Looks like a surface treatment only, so I wonder how long it will last?
I have used this process on my seats before, they dye holds up pretty well I have had this done for over a year. The only places I had trouble is where I used the crack filler. Other places held up great.
Since this has no cracks I expect it to last a while. If I have to reapply in a few years I will just consider this another maintenance item to keep the car in top shape.
Kiven422
Car: '93 Infiniti Q45
'94 Infiniti Q45t
Amazing job silver! Did not expect it to be as good as that!
