Q45 RUNS HOT WHEN A/C IS USED ON HOT DAYS
bpeesy
Car: 1990 q45
My Q will run hot whenever I use my A/C during the daytime. at night I'm ok - any ideas?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
is your condensor fan coming on?
Bad Tstat, weak radiator ar ethe likely cause if the fan is coming on.
bpeesy
Car: 1990 q45
the fan is turning, but I don't here a noise to indicate that the fan is actually working. On my toyota, when the radiator fan comes on I here the idle raise on the car and can hear the pull from the fan clutch. But on the Q I don't hear anything. the fan is turning, but I thinks that's just because it's automatically supposed to. I can't tell if its working
elwesso
2007 BMW M Coupe
thers another fan in front of the condensor that should be on...
Go through the entire cooling system.
Pull radiator, flush if necessary. Clean condensor (almost always the culprit) by pressure washing it from the inside-out, flush rest of cooling system, new t-stat, new temp sensor, check hoses and belts, refill with distilled water (70%), coolant (25%) and a bottle of Water Wetter.
