Q45 rotors
EckOMaN2k
Well im going to be doing a q45 brake swap on my 1995 240sx. An i wanted to know does it matter if i get abs q45 rotors for car since my car has ABS? Or can i just use the regular factory rotors from a q45?
szh
Car: 2018 Tesla Model 3.
EckOMaN2k wrote:Well im going to be doing a q45 brake swap on my 1995 240sx. An i wanted to know does it matter if i get abs q45 rotors for car since my car has ABS? Or can i just use the regular factory rotors from a q45?
All Q45's have ABS too. So, regular factory rotors ought to work for your needs assuming the fit is okay (which is not something I know anything about - for your car!).
I bought my Bradi rotors (sister company to Brembo) from Irotors.com - these were slotted and cross-drilled, but you can get them without these. They also do Zinc plating, which prevents the rotors from rusting. Excellent product and reasonable prices (a bit less than OEM - which you can get from Joe at Scottsdale Infiniti ... he has a web site and is a sponsor here, I just forget the name!)
Z
