IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Sat Mar 06, 2004 11:48 am
i believe they are just a little off.
the J30 and Q45 use the same brakes. the Z32 uses the same diameter rotor, but the J and Q use a 28 mm thick rotor, while the Z uses either a 26 or 30 mm thick rotor depending on caliper.
