q45 rear hubs on a s14
illdrifter
Car: 90 240sx hatch w/ dohc swap ... 90 300zx w/ under 50k ... 90 240sx coupe waiting on red top Sr ... 95 240sx se gutted and about to get a notch top Sr swap .
Ok so I know there is a lot of info out there on this topic . I have searched and searched without being able to find what I need . My issue is I just got a s14 with the 4 lug rear subframe . I also got a q45 diff and axels as well as getting the complete aluminum uprights with hubs attached . I'm wondering what would be involved in using the complete uprights instead of just swapping hubs . I know I will need a z32tt drivers side axle and will have to redrill the input shaft to accept true s14 driveshaft . I need solid info on using the q45 uprights and a solid way of getting the disk drum ebrake setup to work . Any help would be greatly appreciated . Thanks
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
The drum e-brake setup will work with z32..2+2 cables. As far as the uprights, to my knowledge makes the strut bind up because of the angle and is a no go for the s14. Everything else you've seam to hit spot on.
