vr4_for_fun »
https://forums.nicoclub.com/vr4-for-fun-u4393.html
Thu Jan 30, 2003 4:52 am
Hi,I just bought a 98 Q45t with 77,000 miles. I've checked all the maintenance records and everything seems in order including a transmission flush at 55k. I seem to be getting a vibration in the rear end of the car starting about 40 mph which doesn't seem to change if I put the car in nuetral. I know it's not the tires cuz I just put new snows on the car and nothing changed. I have it scheduled to have the rear diff fluid replaced tomorrow with Redline Shockproof/Mobil 1 mix (any idea how much the rear diff holds???). I am also planning to have the transmission fluid and filter replaced with Mobil 1 as soon as I can find someone to do the work as I live in New Hampshire and the closest Infinity dealer is over an hour away. Is there anything else I should be checking?? Also, I've already had the coolant flushed and replaced and have a K&N air filter on its way. Anything else I should be planning to do?
Thanks very much for any information/help you can provide!!
By the way, I bought the car in Texas and just drove it the ~1800 miles back to NH! It was a great road trip and the car is terrific!! I even averaged about 22 mpg cruising 80-90! I thought that was great for a v8!!!
Thanks again!Randy98 Q45t (The Lowrider ;-) )2002 WRX (~285 HP):icesangel
