Q45 rear end Help!!!!
R-Yahne_240
Car: 92 se coupe stock (dd) 93 se fastback (race car)
i was on fresh alloy and saw the write up on the Q45 vlsd swap in a s13 so i was attempting it and i cant get the axles out of the q45 hubs
is there a special trick to getting them out or just beat them out we tryed alot of stuff help help help
R-Yahne_240
bump come on guys im about to go to auto-zone in the morning and use the z-net system lol
anyone know the little trick???????
r3v_v3ng3
Car: 91 fastback ka-t
are you talking about the axle bolt or the axle is stuck on the hub?
trahc
Car: 93 Nissan 240sx se
i used 2 pry bars across from each other , it popped right out. and i never saw mention of the shimms in the old housing remember where they go. on one side you have 2 shimms one is thick and one is thin. put them back exactly how they came out. i am assumming you are gonna put the internals back in your houseing. and for the record the car isnt nearly as fun to drive with a stock KA after the swap, rear end doesnt get loose as easy or at all.
R-Yahne_240
it is stuck in the hub
this suxxxx
and im running an sr in that car
IBTL
Car: 97 240SX
If you're beating them out I found a little trick that protects the threads on the axle. Leave the axle nut on the axle, not tight obviously, just thread it on the end so that the end of the axle is almost flush with the nut. Then you can go to town on it without worrying about trashing the threads. It also gives you a larger surface area to hit with the mallet. I damaged the threads on one of my axles trying to beat it out with a rubber mallet, almost couldn't get the axle nut back on. Yay.
R-Yahne_240
yeah thanks but i did that
ps they still didnt want to come out
