q45 projector retro fit on g35 headlight anyone know how?
sexcpr69
Car: 2006 g35x
i seen somebody on cardomain wit the q45 projectors inside the g35 headlight on da bottom fog light i was wondering how can i do that and also take out my amber signal light and make it clear? here the pic http://www.cardomain.com/ride/2638549/3
Modified by sexcpr69 at 8:29 PM 12/4/2009
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
It will take a lot of work. If you feel comfortable doing this yourself, then very little explanation is needed.
The orange turn signal can be turned into clear.
1. You need to bake open and seperate the headlights2. Remove turn signal piece3. dremel out all the orange (carefully)4. use a white flourescent style cover piece and cut to size. (can find small squares at Home Depot)5. glue in the clear piece to the turn signal piece. 6. Re-assemble the headlight and reinstall on the car.
